I'm the new owner of this copen. I had it dynoed after I bought it and it made 69.9 at the fly! :/ runs insanely rich at top end as well so that will be getting sorted as that's losing lots of power. Granted the dyno I used is used to having things that are like 400+ bhp on it so that may not have helped things :')
It only made 69.9? Can running rich cause that much power loss? Could it be due to the ecu? I dont know much about the ecu on copens but on other cars any sort of performance mod will need a remap to kind of fully take the modification into consideration. I thought it would be running near 100 after the work its had done! At least you know you have a good Copen, apart from running rich.
It's running crazy rich up the top end apparently. I'm yet to wire in my aem wideband to see just how bad it is. After that I'll be going for a hks fcon piggyback Ecu to sort the fuelling out. I've upped the boost to .9 of a bar for the time being to pull the fuelling back into a normal range as well as per the dyno guys advice and seems to be running a lot nicer and a lot quicker. Still find it weird how it doesn't have any lag from the turbo what so ever though
I'm just in the process of having a turbo fitted to my own car, this too with being a larger blower has no lag, match ups are definitely getting better these days
Sorry, I've seriously confused matters, my car which is having the turbo isn't a copen. I'll get me coat, lol
