Removing Air Vent
Discussion in 'Problems, Fixes, Tips...' started by Number6, Apr 7, 2014.
  1. Old Badger
    Old Badger Copenworld Regular
    South Croydon
    2004 Copen
    2016 Honda HR-V
    By the way Joeleow managed to get his off for rechroming. Or maybe the guys in the workshop did it!
  2. ClareL
    ClareL Copenworld Veteran
    1.3 2008 Copen
    Not yet :-(( my husband decided he would wait for the summer so he could get the roof down and have more space (and better weather) to have a proper look at it!
    I think that meant leave it for as long as possible before I go at it with a screw driver:p
    If we ever succeed I will post a "how to...."
    Jowleow did you manage to remove the vents yourself?
  3. ClareL
    1.3 2008 Copen
    My husband is also fitting my leather handbrake "in the summer".
    I can't wait for the first warm sunny day :D
  4. Old Badger
    South Croydon
    2004 Copen
    2016 Honda HR-V
    Good luck for both jobs!
  5. Number6
  6. Old Badger
    South Croydon
    2004 Copen
    2016 Honda HR-V
    Is this anything to do with "50 Shades"?? :rolleyes::rolleyes::eek:
  7. ClareL
    1.3 2008 Copen
    I hope not Old Badger because I am about to watch Number 6s you tube link :eek:
  8. ClareL
    1.3 2008 Copen
  9. Number6
    Ah! Those are easy to replace as well - just take care taking the centre console out, as there are about 4 wire connections that need to be disconnected.
  10. ClareL
    1.3 2008 Copen
    Thanks, I will let you know how he gets on - or how I get on when I get fed up waiting :D
  11. ClareL
    1.3 2008 Copen
    I took my Copen for it's MOT and a service at Cattermoles in Ipswich today. They are an ex Daihatsu dealer and great with Copens (it is a 3 hour round trip for me from South East Essex but they are better than anyone else any closer).
    So I took my lovely shiny vent rings too as they said that they would try to fit them.
    Their verdict is - all you can do is prise the old ones off, breaking the tabs, they didn't want to risk damaging anything else in the process so it is back to my husband doing it on a sunny day :D
  12. ClareL
    1.3 2008 Copen
    So, the only way to remove these vents is to force them, I tried getting behind them to twist them through a quarter turn, couldn't! So resorted to brute force... Masking off the area around the vent with tape to hopefully prevent any slippage/damage, simply get a smallish flat head screwdriver and force under the edge of the vent ring, trying to lift it if you can to enable getting the screwdriver under, when you are under the edge, twist until you hear a snap, it's the only way... Move around the vent to the next quarter point and repeat. When you have two 'broken' clips, you will have enough leverage to lift the vent ring and then turn the whole assembly through 90 degrees anti-clockwise, thus releasing the collar that the ring is mounted on, you can them easily remove the ring from the collar without breaking the remaining clips.
    When you have replaced or resprayed your vent ring, you simply pop it back on and then locating larger locator lug on the ring, place this at 9 or 3 o'clock position and just press home until you here a satisfying clip and it is nice and secure again...
    Simples :D
  13. Number6
    Yeah, someone on the Copen Facebook group said the only way to do it is with a screwdriver.
    Did you replace yours? They look custom. If you did, I'll happily take the original ones off your hands :)
