Remote roof operation.
Discussion in 'Modifications' started by thewiltshirehardys, May 30, 2013.
  1. DaG
    You can buy a load tester from about 20 quid. The one in this link is like the type battery sellers use. They clamp the leads onto the battery, or some testers just have two probes to jam onto the battery terminals, the machine then tests the battery under working conditions.
    http://www.ebay.co.uk/itm/500-Amp-C...er-12V-Car-Battery-Tester-A6604-/130963174862
  2. joeleow
    joeleow Copenworld Regular
    Singapore
    Rob, how did it go with the remote?
  3. joeleow
    Singapore
    Hope to check if any 659cc owner can open the roof without starting its engine (or put to Acc)?
  4. dsb
    I can open mine without the engine running - but I do have to put on the power enough - in the same way as radio/fan operation.
    I don't normally do it though - even the dealer told me it's best to startup first to avoid running down the battery.
  5. joeleow
    Singapore
    So the 1.3 Copens can open roof without even inserting the key?
  6. joeleow
    Singapore
    Went to the audio shop to test the battery, which was dated Aug 2012. It is pretty weak and I was advised to change it.
    After the battery change (a bigger one), the roof operation works without starting the engine but I need to turn the power ON first. :)
