DIY: Open roof while driving
Discussion in 'Modifications' started by MrCopen, Jul 5, 2013.
  1. joeleow
    joeleow Copenworld Regular
    Singapore
    Thanks Andreas! Good to know that before my attempt. :cool:
  2. joeleow
    Singapore
    I just learnt something new from the SG Copen meet today. The guys can operate the roof while driving slowly... they simply engage the parking lever with just one click up and the roof can be operated. I gave it a try earlier and it works! :D:D:D
    Let me know if it works for you guys.
    Disclaimer: not sure if such an action would confuse any of the electronics though. ;)
  3. copencat
    copencat Copenworld Regular
    Surrey
    my parking lever is tighter than a proverbial ....
    one click and it is done!
    but good to know!
  4. Number6
    Mine is the opposite way. The hand brake cable tightness can be adjusted by taking out the arm rest and twiddling a nut.
  5. DaG
    One notch on the handbrake, so it's as simple as that? I kind of thought it would be linked to the car being stationary, plus the handbrake. I'll try it next time I have the roof down.
  6. MrCopen
    MrCopen Copenworld Member
    New Zealand
    Daihatsu Copen 2004
    I might try that after work on way home.
  7. MattMacc123
    MattMacc123 Copenworld Member
    Lanark, Scotland
    tried it but you cant go over 5-10 mph as it beeps a lot and then stops :( but still better than doing it stationary! :D
  8. joeleow
    Singapore
    Good when driving slowly in a carpark. :D
  9. DaG
    I tried it at walking pace with one notch on the handbrake and it didn't work.
    No beeps or alarms going off, just nothing. Maybe the later cars had something added to prevent drivers from doing this.
  10. joeleow
    Singapore
    That's strange... it seems like the Copens that I come across in SG is able to do this. A few members here reported positive results too.
    Maybe we can do a poll to see if its due to the model (1.3 or 0.7) or year of manufacture?
    Mine is a 0.7 built in 2007.
  11. scooty
    Maybe one click is just not enough?
    I assume at least the handbrake warning light should light up?
  12. DaG
    My handbrake light came on at one click. I tried it today with two clicks and it still didn't work. My cars a 1.3 maybe it only works on earlier cars.
  13. Coxsie
    Coxsie Copenworld Member
    Watford Herts
    Copen + Signum
    It works
    Tried it today in works carpark, putting roof up will moving that is :p
    one click on handbrake, with warning light on.
    Works OK if speed kept below approx 4 to 5mph, if you go faster
    alarm bleeps rapidly at you, and the roof stops moving until you slowdown.
    I have 2007 1.3 model :)
    Good luck if you try it
  14. fastlap
    fastlap Copenworld Newbie
    copen 0.6 2005
    will this method still cause faults to be stored in the ECU and fill it up? would like to try it and this way seems the preferable choice to me? any info regarding filling up the storage space in the ECU memory would be much appreciated.
  15. freddyzdead
    Gosford, NSW, Australia
    2003 Copen
    I know this is an old thread, but it seems kind of obvious that if you open the back-hinged boot lid at 70mph, the wind-shear would likely bend it backwards and maybe snap it off. I have often put the roof up or down while sitting at traffic lights. Why do you have to be moving?
  16. BarnsleyRob
    It works just fine on the Lockheed Martin version at speeds up to 500 mph :nerd:
