Boot/roof not working
Discussion in 'Problems, Fixes, Tips...' started by Debrisbits, Aug 23, 2016.
  1. Nedryerson
    Nedryerson Copenworld Regular
    0.66 Copen 2003
    Fiat 500
    Tyke, 've been reading this thread and you have my sympathy. I've not had any problems myself (Wife left me, house burned down and got fired) with the roof I mean. But at least here is the UK there are former Diahatsu dealers who can help.
    Mind you if the pump works it has to be mechanical I would guess.
    Ned
  2. Nedryerson
    0.66 Copen 2003
    Fiat 500
    Tyke, I've been reading this thread and you have my sympathy. I've not had any problems myself (Wife left me, house burned down and got fired) with the roof I mean. But at least here is the UK there are former Diahatsu dealers who can help.
    Ned
  3. tyke
    tyke Copenworld Regular
    Thailand
    I can see why she left you; you keep repeating yourself........................;)
  4. Vin Petrol
    Wife left you? At least you had some good luck in among the bad then ;-)
    tyke likes this.
  5. martin christford
    martin christford Copenworld Newbie
    wales
    daihatsu copen
  6. marnob
    marnob Copenworld Regular
    West Coast New Zealand
    Copen L880K 2004
    Really annoying when links disappear like that!
    I still have a copy of the fault codes for the L880K.
    Not sure if the apply to the newer model.
    This forum really needs some work done on it.
    Anyway, I will post it here.
    Not sure of the pins though..if I can find that I will post it too?
  7. martin christford
    wales
    daihatsu copen
    Thanks its the pins i really need because i have fitted a new roof ecu due to water damage i just need to reset it and i think all will be ok, mine is a 53 plate which i bought for my daughter that came with the fault which i am trying to resolve.
  8. marnob
    Copen L880K 2004
    Yeah, I just thought its useful anyway..
    I have a copy of that somewhere..not sure where but I might be in the glovebox so I will have a look shortly and see.
    Nah, can't find it.
    Will post If I do.
    I reckon I wrote it down on some paper.
    I also have the file somewhere on the computer but I just can't find it..
    I bought mine with a fault as well..Turned out to be a loose wire in the plug!
    Nothing wrong with the ECU?
  9. martin christford
    wales
    daihatsu copen
    Mine was badly corroded so needed to be changed, if you manage to find the pin bridge i think my problems will be solved, thanks.
  10. reds15
    reds15 Copenworld Newbie
    Singapore
    Hi there, would you happen to have the name and/or address of this shop in Yishun/Nee Soon? I've the same problem now and looking to get it fixed. Would be great if you still remember how much it cost? PM me if it's not convenient to share it. Thanks!
  11. Abdul Rahim
    Abdul Rahim Copenworld Newbie
    pakistan
    how to
    how to clear the air from hydraulic lines?
