Possible fix for Seat belt Guide retraction
Discussion in 'Problems, Fixes, Tips...' started by Adam K, Sep 2, 2011.
  1. Adam K
  2. machinehead
    Interesting.
    Thanks for posting that Adam.
    M.
  3. Adam K
    I've got a set coming from Japan, cost me £15 delivered.
    Fingered crossed it works. It can't be any worse than standard.
    My Parcel from Japan arrived today. Just need a dry weekend to fit it.
  5. Adam K
    I've just fitted these to my car. A bit disappointing, it hasn't solved the issue, but it has given a very marginal improvement. :(
    Seem to work better on the passenger side belt though.
    I'll post some picture later of the fitting.
    You could try yourself. I think a screen protector for a touch screen devise, with a good adhesive would do the same job.
  6. Adam K
    After driving home tonight, I've changed my mind a bit. The improvement is better than I first thought.
    It's better than it was but is not perfect.
    It has made a better difference than buying the new seat belt guides!
    Pictures up in a bit.
  7. Adam K
    Here's the spare part as arrived from Japan
    The contents:
    Instructions in Japanese but with pictures.
    A piece of Velcro (the rough side).
    Two sticky backed bits of smooth shiney plastic film.
    First off you need to get access to the the setbelt top guide. Just pop out the wind deflector, all the plastic panel just pull off. As you can see mine are a little dirty, thanks to a previous owner who smoked!
    Get the bit of velcro behind the belt & rub back & forth on the guide.
    Then feed in the sticky plastic & pull off the pull tabs (the red & blue bits).
    Stick the plastic film down. Then pull down on the belt & pull it back & forth to rub on the plastic film to help stick it down.
    Then put all the trim back together. Now you have a slightly better seat belt action. :D
  8. Rex
    Some years ago, I had a similar problem on another car. What made a big difference was soaking the belt in hot water and normal washing detergent. I think the belt gets soiled after years of use and stiffens up.
    I'm not sure if it is advisable, but it worked for me.
  9. Adam K
    When summer comes around again, I might give it go.
  10. Tiddlycar
    Tiddlycar Copenworld Newbie
    Want my seatbelt guides?
    Just sold my Tiddly Car so am putting my chrome seatbelt guides up for sale on Ebay. Bought them from Kumoi Motors in Japan and they really make the difference. Save yourself a few quid by buying them from the UK!
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
    Ebay Item number: 380410469577
  11. Rex
    An update.....
    Tried washing as above, but didn't make a lot of difference. I'm still convinced the problem is due to the belts getting less pliable as they get older.
  12. nertman
    nertman Copenworld Regular
    Braintree Essex
    57 plate copen
    Customised MGTF
    Nissan Terrano
    Suzuki GSR
    Kawasaki W800
    roller type guides
    Talking to our spray guy earlier today,he had a simular problem with some VW'S that he was rodding and they located a roller type guide that didnt jam or slow up the belts,
    Hopefully he will get back to me where and from what they came from
  13. DaG
  14. ThomasA
    ThomasA Copenworld Newbie
    Johannesburg, South Africa
    Seat belt issue & tyres
    Thanks for the info I will try the clean up with soap and warm water and will report after the week end.
    The next advise I like to have is about tyre size.
    I find the 165/50 R15 V is not easily available in SA (I just fitted 4 new as per specs.). I would like to know if we can use 175/50 R15 V or any other, in the front to achieve extra ground clearance.
    BR/ThomasA
  15. Klausanta
    Klausanta Copenworld Member
    Surrey
    Renault Megane
    Hi
    I had difficulty finding many options for new tyres in the UK as well so eventually I stuck with the original size made by Bridgestone that cost me £67.00 each fully inclusive of fitting, balancing and tax.
    Have a look at this site.
    http://www.alloywheels.com/Tyre_Calculator
    Click on the 'Show / Hide specific tyre size to compare against' option.
    You can put in your current tyre dimensions and compare them with alternative sizes. It will then give you the percentage difference (in your case 1.87%) and the range of tyres available within specific (and selectable) guidelines.
    This site recommends that the difference is kept to 1% although I am reliably informed that you can go up to 2.5%.
    I hope this helps
    KS
