Windows - Problem?
Discussion in 'General Chat' started by mark73, Apr 30, 2013.
  1. mark73
    mark73 Copenworld Newbie
    Leicester
    Copen 06 plate
    Hi all
    long time since I have been here
    This morning I put my passenger window down to clear the water off but it wouldnt go back up. Eventaully it did
    When I got to work I opened the drivers window and again it did the same. In stead I noticed the little window that usually only goes down when the roof is put down went down . I managed to do this a few times
    Eventaully the window went back up
    Any ideas why they are not closing straight away? Bit worrying
    I would've said to just put some silicone lubricant on the window runners.
    This will help them slide up & down. Reducing the strain on the window motor.
    It's very strange though that the rear quarter window also went down.
    The ECU in the boot also controls the window operation. Have your checked inside your boot for water? Look under the jack.
    If there is water I would then check the ECU for water ingress.
    If it's all dry in the boot, maybe your battery is dying.
    Strange things seem to happen to the Copen when the battery is dying.
  3. gary cad
    gary cad Copenworld Newbie
    Kent
    Yes Copen + Honda CRV
    Have had a similar problem in the past.
    Resolved by dropping the lid down and then it all seemed to sync back to normal. Also agree that it is more than likely a battery issue, check the connections as mine has become loose recently
    Keep On Copen On
  4. mark73
    Leicester
    Copen 06 plate
    brilliant thnks all for this
    will do the hood thing first failing that a new battery it is - it all comes at once doesnt it
    dont dare put my wondows down!
  5. Adam K
    Don't forget to check for water in the boot.
  6. Rex
    From memory, I thought the window ECU is the one towards the front of the car, drivers side (still in the boot), not the one by the jack. I think it is located at about the same position as all the water runs into when you open the boot when wet!!!
    Worth checking for damp patches there.
  7. mark73
    Leicester
    Copen 06 plate
    what a nightmare
    thanks all for this
    will have a check when i get home and also try the roof trick first. Fialing that a new battery it is
  8. Rex
    Pictures of window ECU in THIS thread.
  9. mark73
    Leicester
    Copen 06 plate
    brilliant thanks for this
    At least i know what to look for in there
    Im really hoping its nothing to do with that thing - if it is im guessing you have to dry it out?
  10. mark73
    Leicester
    Copen 06 plate
    oddly enough left work yesterday and the windows were fine also this morning too!
    Fingers crossed all is well
