/ Register
Questions on 2nd row windows
Discussion in 'Modifications' started by Davetan86, Mar 1, 2012.
  1. Davetan86
    Davetan86 Copenworld Newbie
    My first post! :D Whenever we bring up our top, i notice that we are only able to wind up the 1st row of the windows. Is there any way to mod our 2nd row windows to be wind up together with the 1st row with the top up?:think:
    Hi Davetan86,
    Welcome to Copenworld.
    So you want both windows open when the roof is still closed?
    Apart from doing a bit of electrical re-wiring. The only way is to go through the roof opening sequence. The windows roll down first. Just stop before the roof lifts.
    Or do you mean when the roof is in the boot, you want to raise the rear windows?
    That can easily be done.
    See here:
    http://copen.4.forumer.com/index.php?showtopic=1128
  3. scooty
    Hi,
    welcome and congrats to your first post!
    Think, it's better to post it in this forum as well:
    After having opened the roof you can press and hold a little button where ususally the roof-catch grabs in (see red arrow in pic):
    If you then operate the windows up while holding the button, the 3/4 windows will go up first, then the normal windows.
    The 3/4 windows will remain up until you start closing the roof again.
    Sorry, but for what to do to make it automatic, I cannot help.
    Hope this helps,
  4. dwayner
    dwayner Copenworld Regular
    Mornington Peninsula
    A 2005 copen and a
    Camry Sportivo
    dwayner
    mine must have an electrical fault since i can open the small side windows when the door windows come done, without the roof opening at all - it was only after i read here and checked in the manual that i found this to be diferent
  5. Davetan86
    Gee! Thanks for the guide! Didn't notice there is a small button in between the roof latch. I tired that abd it works! But it can't be wind down until u put the top up again.:(
  6. Rex
    Yep, that's normal I'm afraid. Got to try to put the top up to get the rear Windows to go down.
