Windows roll up wet
Discussion in 'Problems, Fixes, Tips...' started by alz2605, Feb 2, 2014.
  1. alz2605
    alz2605 Copenworld Regular
    Ceredigion
    VW Golf TDi
    When I roll up the windows they come up with a film of water on the inside of them even on dry days.
    Anyone else getting this issue? Are my doors full of water?
  2. dsb
    I do tend to yes - i'm guessing it's as the rubber seals are not totally tight.
    doubt you are full of water though - if you take off the inner door cards to change speakers etc you can see the actual metal of the door - with a polythene film on it.
    guess that helps form condensation.
  3. Rex
    I've never noticed wet windows on the inside.
    The inner seal is part of the door card.
    Just check the holes at the bottom of the door.
  4. NeilSmith
    NeilSmith Copenworld Newbie
    UK
    2008 Copen 1.3
    I've just bought a Copen, and my windows roll up dirty, which is annoying. I've cleaned them a few times, but whenever they go down into the door, they come up dirty again. I'm going to have to do a bit of disassembly and investigate.
  5. jez77
    Probably just dirt on the underside of the weatherstrip.
    It's normally just held on with Spring clips although I've never tried the copen you should be able to pull it off by carefully hand once the window is down and clean it.
