Wheel Size
Discussion in 'Modifications' started by Kevin Batchelor, Jun 27, 2018.
  1. Kevin Batchelor
    Folkestone, Kent
    Hi... I am looking to get new wheels for my 2007 Copen. Can anyone give me the original wheel sizes and also what's the maximum wheel size I could put on?
    165/50 R15 on 4,5x15J
    Maximum will be 17 inch alloys with whatever wheels you find that fit
    Kevin Batchelor likes this.
  3. Kevin Batchelor
    Folkestone, Kent
    Thank you Salieri. And what is the maximum width of a 15 inch wheel? Is 6.5 x 15 ok?
  4. Salieri
    Depends on what your local car roadworthyness testing facility is willing to accept :D
    You can put almost any kind of tire on there, but you might have to invest in wheel spacers, broader wheel arches, spring rate reducers (if that is the correct term?) etc.
    I think I have seen 6.5x15, but I know there is a document somewhere here that shows every possible combination and the work you have to put in in order to get through MOT/TÜV
    Tony likes this.
  5. welz
  6. Vin Petrol
    It's MOT not TUV Salieri, our tests don't care about approvals, you can literally just slap anything that fits on and if it drives to the MOT station without them falling off, they're fine.
    Dezent Ti 5jx15, 4x100pcd, 45 offset on Uniroyal Rainsport 3 195/45/R15 with kerbing rib are what I switched to, I've attached a pdf of wheel sizes used by our German friends but they're a lot more restricted than we are.
    Mine needed no work doing, no rubbing and handling is fine.
  7. Kevin Batchelor
    Folkestone, Kent
    Thanks Guys
    All useful and thanks for taking the time to respond. :)
  8. Kevin Batchelor
    Folkestone, Kent
    Hi
    I've gone for Dezent Ti too. Recommended by local garage and a clear easy fit. Having them fitted this afternoon! Yeeiii!
    Vin Petrol likes this.
  9. Coupon
    Coupon Copenworld Newbie
    Durham
    Cope 1.3 Roadster
    How do you get a 195 tyre on a 5J rim?
  10. Shahram Azimi Nobar
    Shahram Azimi Nobar Copenworld Regular
    Egham
    Dear Copen Riders,
    I am considering increasing the aspect ratio of the tire to 165/60R15 instead of the OEM size 165/50R15. This change should provide a more comfortable ride, especially on bumpy roads. Has anyone tried this?
    Thanks, everyone.
  11. Tieak
    Tieak Copenworld Member
    Stirlingshire
    Copen 1.3 2007
    Renault 5
    Seat Leon
    I did switch mine to 165/65R14, which involved getting new (to me) hubs too. It did make for a better ride, most of my teeth fillings remain, but it's somewhat subjective.
    For what it's worth, it did increase the wheel circumference a little but judging by the Sat Nav's (GPS) speed indicator, the car's speedometer still over estimates, though less so that before. I guess all tyres don't provide the same ride smoothness either - mine are the snappily named Toyo NanoEnery 3 Premium Eco
    For completeness, although mine was a somewhat large increase to the tyre sidewall (c.25mm) , I never found any difference to the handling - especially at the limit but mainly because I avoid that sort of thing.
  12. Shahram Azimi Nobar
    Egham
    I used this website for a comparison between 165/60R15 and the OEM size 165/50R15: Rim & Tire Size Calculator. Custom Offsets
    It turns out the speed increases as expected, while the speedometer shows a lower speed. To compensate, I need to make sure to stay around 5 mph below what the speedometer indicates. The only disadvantage shown is a change in the negative scrub radius (about -6 mm). I'm not sure how this will affect real-life driving.
