softer suspension
Discussion in 'Wanted' started by Neil Birch, May 28, 2024.
  1. Neil Birch
    Neil Birch Copenworld Newbie
    Lancashire
    Toyota Prius, Daihatsu Copen
    Is it possible to obtain softer springs? |My wife is 86 and it's getting a bit hard for her! Neil
    JohnnyG likes this.
  2. Tieak
    Tieak Copenworld Member
    Stirlingshire
    Copen 1.3 2007
    Fiat 500
    Seat Leon
    Greetings,
    Another, perhaps less involved, option is to go for smaller wheel rims…from 15 inch to 14 inch…with a corresponding increase in tyre (sidewall) size. The idea being the bigger sidewall will give more flex and so a softer (or perhaps better described as a less firm) ride.
    The bolt patterns, offsets etc are given in the link. I have found these to be the same to some other small Japanese cars such as older models of the Nissan Micra, though you should check for yourself to be sure.
    2007 Daihatsu Copen - Wheel & Tire Sizes, PCD, Offset and Rims specs
  3. Neil Birch
    Lancashire
    Thank you I'll look into that.
