Shifting issue
Discussion in 'Problems, Fixes, Tips...' started by Rebel250, Mar 17, 2016.
  1. Rebel250
    Rebel250 Copenworld Newbie
    Belgium
    Honda Rebel250
    Kawasaki W800
    Daihatsu Copen 1.3 2007
    BMW Grand Coupé 2016
    Hello,
    I Have a 2007 Copen 1;3 with 110000 kms. when i want to put him in his first or his revers, it 's not going smooth.
    Anyone any idee what it can be ?
  2. Denis
    Denis Copenworld Newbie
    Russia
    L880K
    Check clutch cable tension
  3. jcuyckens
    jcuyckens Copenworld Member
    Belgium
    Volvo XC60 2015
    Toyota Corolla 2004
    Rover 45 V6 2005
    Daihatso Copen 2006
    BMW R850RT & R850R
    Yamaha GTS1000 1993
    One of the two connection bars, the one NOT connected to the gearshift, uses a rubber joint, this has increased clearance.
    disassemble, grind rivet, drill and put some M6 thread in there and with some washers you can increase the pressure on the rubber joint, so the clearance gets lower.
    This modification makes the gear shift more sturdy.
