Rustproofing today
Discussion in 'General Chat' started by hiramscodd, Nov 30, 2014.
  1. hiramscodd
    hiramscodd Copenworld Regular
    53 plate black copen
    transit
    I pressure washed the underside on Friday to get the bulk of the crud off.Let it stand till today so it dried thoroughly .
    Stripped the back end down ,i was surprised at the amount of fixings on the bumper
    Then applied this in copius amounts:D:D inside every part i could get access to
    The rust under there wasent too bad to be honest ,i think its only been used in fair weather .Hoping it should last a few years now
  2. Old Badger
    Old Badger Copenworld Regular
    South Croydon
    2004 Copen
    2016 Honda HR-V
    Great job! :)
  3. threepot
    threepot Copenworld Regular
    They rust down there from the inside out.
    Condensation forms on the inside of the panel, and they were not coated properly from the factory inside the arch on the side you cannot see.
    If you take all the paint off the side you can see, you will find it is rusting under the paint. It is rusting from the inside out!
    Make sure the drain gap at the bottom of the sill edge is clear too.
  4. hiramscodd
    transit
    Took the bungs out and sprayed in there also ,drains on sill bottom are clear i sprayed in there also through the bungs on sill underside.
  5. hiramscodd
    transit
  6. Cayuga Duck
    Cayuga Duck Copenworld Newbie
    Tasmania
    Daihatsu Copen,Holden rodeo ute, Kia Sportage, Kawasaki ZZZ1100
    Hi, could you please tell me which colour you used please?
  7. hiramscodd
    transit
    The Red one seems to work ok
  8. threepot
    Tidies the seat up nicely that does.
