Hi all happy new year to everyone (sorry its a bit late) hope you all had a good christmas.Anyway just a quick note to let you all about the RUST woes with my little white copen, my rear arches,sills and bonnet have all sucome to the dreaded RUST .Also my exhaust is about to fall off!!!!!!!!!!!!!!!!!!! any way things are in hand car is going in for a full repair and respray in febuary,exhaust is being replaced towards the end of the month with a stainless system (taking car tommorow for another quote). hopefully she should be back to her best around march time(fingers crossed) MAKE SURE YOU ALL CHECK YOUR ARCHES AND SILLS FOR THE BEAST!!!!!!!!!!!
Once you get the bodywork sorted make sure you get some Dinitrol into the cavities. https://www.copenworld.com/vb3/showthread.php?t=535&highlight=rust+protection
Having the car fully undersealed and will get the sills treated also DONT WANT IT TO COME BACK!!!!!!!!!!!!!!!!!!!!!! also i think the first repair/paint was crap anyway funny how he has noe gone out of buisness
took advise... We made sure when Dinky was painted last year that every possible spec of any sign of rust was treated,luckly non found but had everything re undersealed just in case Let you know more when i see her again,currently hibernating in the garage under some nice warm covers and kept company by the dehumidifier ROLL ON SPRING...
would be interesting to know how much your stainless exhaust is going to cost? will be be same diameter piping as original?
dwayner i feel fo you guys with the rust problem - so is it the salt they put on the roads in winter? Mine is never undercover even in 40C day like today -never even seen a spec of rust on it, or under it. Is there something you can spray onto it, to prevent the rust from happening?
Rust occurs differently in different countries/climates. Here where its hardly ever hot and not often warm, its generally cool and damp. So its not always rain but damp air that condenses on the inside of metal panels on colder nights (days would usually be warmer to create the humidity) so you get an unseen thin layer of moisture on the metal to constantly but the rust prevention under pressure. maybe even little beads form if high humidity and cold nights and collect in tight spaces. This is one reason why rust appears from nowhere on the wings of cars in UK, appearing through what was apparently perfect paintwork. Now in Saudi Arabia for example, you don't get this type of rust formation. Its mostly dry and warm. Rain evaporates quickly. Not much humidity to get hidden .condensation. But their bonnets and even roofs can get to be just an ocean of rust. This is because they get a near constant micro-abrasion, sand rubs down the lacquer and paint. In contrast the doors can be in relatively good condition. This is why you often see them with covers over the front bumper/bonnet but you don't see then in the UK.
how can i check inside the door - it worries me as when you wind down the windows or wash the car - even the next day you can wind them up and they are wet - so whats happening in the door frame - (women owner !!!)
Follow the how to change your door speaker guide to get behind the door card. http://www.copenownersclub.org.uk/removing-your-factory-fit-speakers/ There's a plastic membrane that stops moisture getting on the inside of the car. There are lots of holes in the bottom of the door for water to drain out. The reason you window gets wet is that on the rear of the rubber lip on the window at the top of the door is a felt like material. This helps the window slide up & down on the rubber. This felt material stays damp for a while.
pipe will be the same diameter will let you know on the price when its finished( i dont think you will be disapointed!!!!!!!!!!!!!!!!!)
thanks adam i asked copenworld if there were any copen car clubs in new zealand twice now with no reply - dont suppose you know of any - would absolutely love it trisha
Exhaust price!!!!!!!!!!!!!!!!! Hi all, had my new exhaust fitted for a few weeks now (full system just to make sure its ok), its great, had it fitted at a local garage to me in Hucknall nottingham, here are the details if anyones intrested, J.A.C WAYNE JACKSON unit 7 plot 1 wigwam lane Hucknall Nottingham NG15 7SZ www.jacexhuasts.co.uk Tel:0115 9635556 mob: 07812 191122 Total price for full system £290 inc vat wayne says he will need the car for a full day if anyone is intrested please give him a call.............
