Replacing reversing light bulb on Copen 1.3?
Discussion in 'Problems, Fixes, Tips...' started by mzungu, Aug 25, 2021.
  1. mzungu
    mzungu Copenworld Newbie
    Leicester, UK
    2008 1.3 Copen
    Dealer says you have to remove the rear panel to replace the reversing light bulb.
    Please can someone give me an idea on what this involves and how to do it?
    Thanks.
  2. GuzziMan
    GuzziMan Copenworld Member
    Densole Kent
    Hi
    In your hand book, owner manual, from the index in the rear of the book it comes under the heading light bulb replacement. Our book which covers the 600cc engine it’s in section 13-27 onwards. It involves taking out the tail light to reach the light below it. Then you flick out the spring clips so you can extract the light and change the bulb. Reassemble in reverse order.
    Hope this helps
