removing speakers.... door cards?
Discussion in 'Modifications' started by dsb, Nov 24, 2013.
  1. dsb
    so i'm looking at...
    http://www.copenownersclub.org.uk/removing-your-factory-fit-speakers/
    I get to the point where I've removed the two circled screws in the door handle and... it magically jumps to the door panels off.
    anyone done this? - do I just need to give them an almighty tug and the whole lot comes off or... ?
    don't want to break something.
    thanks!
    Start at the bottom left corner of the door card. Get your fingers behind the panel then pull towards you. The panel should pop away. The top edge of the door card is tucked in behind the door metal & window. So once all the poppers are free you need to slide the door card up.
    (Woo hoo, this is my 2000 post)
  3. dsb
    thanks - I shall have a go!
