Removal of seats
Discussion in 'Problems, Fixes, Tips...' started by sunlover, Mar 31, 2019.
  1. sunlover
    sunlover Copenworld Regular
    Ayrshire, Scotland
    Lovely sunny day here so decided to whip out the seats to clean them properly and the inside of the car. Can't believe how easy they were to remove, also get a chance to treat where the bolts screw down, just in case of the dreaded rust. Hope weather keeps up for every one and we get the roofs down. :)
    copenforbusiness likes this.
  2. copenforbusiness
    Newbury
    1.3 Copen, CRV, Estima
    Nice time to do this. I will attempt to do this too if only for the rust treatment. Any pointers?
  3. sunlover
    Ayrshire, Scotland
    Hi you will need 12mm hex nut required. 4 x bolts on each seat, easier if you slide seat all way back, loosen the front 2, then slide all way forward to loosen back 2. Our seats are heated so we had to disconnect the cable connector, and cable tie which holds to the seat frame. Then just remove the seat. 5-10 min job if you've got a ratchet spanner. Hope this helps.
  4. copenforbusiness
    Newbury
    Thank you! I'm definitely having a go.
