problem ???
Discussion in 'Problems, Fixes, Tips...' started by bathtowel23, Apr 12, 2012.
  1. bathtowel23
    bathtowel23 Copenworld Newbie
    Glasgow,UK
    Daihatsu Copen And Honda Civic Type S GT
    I seem to have a problem with my radio and clock I removed them today to measure for a new radio,but wen I put it back int neither worked atol. Thought it could be a fuse but not sure which 1 it is the manual isn't very clear,any help would be gr8 thanks......also my gauges are jumping up and down before I start the engine since the problem
  3. bathtowel23
    Glasgow,UK
    thanks adam i will pm him to see if he knows
  4. Pierre
    Pierre Copenworld Newbie
    Switzerland
    Copen 0.6
    Dedicated radio fuse?
    Hi there, after briefly connecting the battery terminals the wrong way around (I know...) my radio decided to shut up. No power. The 7.5A fuse is intact. Where does one look next - does it have a dedicated fuse, and if so where do I lOOk for it please?:eek:
  5. ClareL
    ClareL Copenworld Veteran
    1.3 2008 Copen
    There is also a fuse on the back of the radio itself, which means taking it out to discover if its that, we had a similar problem, none of the fuses were gone but the unit was dead... So we swapped it for a double din :D
