P1560 code
Discussion in 'Problems, Fixes, Tips...' started by Jon Lindal, Oct 24, 2021.
  1. Jon Lindal
    Jon Lindal Copenworld Newbie
    Copen 2010
    Hallo everyone.
    I am new here.
    I have a 2010 Copen with the 1,3 liter engine that I have had for 2 years now. Until last week it has been problemfree. But then the code P1560 showed up at a regular inspection. (MOT) Does anyone have a solution to this other then going to a Daihatsu service (which in my case is pretty far away).
    The check engine light blinks briefely when I turn on the key, then when the fuel pump stops it comes on. When I start the car the light turns off again. But the code remains.
    If someone has a solution I would appreciate it.
    Regards,
    J.
  2. GuzziMan
    GuzziMan Copenworld Member
    Densole Kent
    Hi Jon
    Hope this is of some help,
    Under B8 engine control system, in the workshop manual page B8-37 code P1560/61 diagnosis ECU backup power source circuit malfunction content open wire in backup power source circuit malfunction of the EFI ECU.
  3. Jon Lindal
    Copen 2010
    Thanks. I will look into this.
