Oil Filter relocation
Discussion in 'Modifications' started by Number6, Dec 19, 2017.
  1. Number6
    Does anyone know which kit is best for the oil filter relocation in the 660?
  2. MultiplexMan
    Sydney, Australia
    KIA Carnival YP, Copen
    When I was researching it, there was a beautiful alu machined piece of art from a small shop in Japan. Total CNC porn. I've been searching for that shop ever since I lost the link :cry:
    I ended up buying stock parts (Earl's) and machining them to suit the Copen. Hoses were supplied direct from Goodridge and made to measure. Sandwich plate was tapped for pressure sensors before and after the oil filter.
    I logged differential pressure via the Blitz SBC unit. It is an old practice. Differential pressure will climb as the filter media gets clogged. Once the filter is "blocked" - differential pressure drops to zero as the filter bypasses internally (spring loaded bypass).
  3. MultiplexMan
    Sydney, Australia
    Searched through an old archive and finally found it!
    Kit was by Works Izumi.
  4. MultiplexMan
    Sydney, Australia
    I was not keen on their oil lines, otherwise the kit looked nice and neat.
  5. MultiplexMan
    Sydney, Australia
