Odometer conversion
Discussion in 'Modifications' started by Number6, Oct 26, 2017.
  1. Number6
    Anyone know if it is possible without taking half the car apart or desolder chips, to switch the odometer from miles to kilometers?
  2. BarnsleyRob
    I think you can just buy and fit alternative dials. People on here have changed them for aesthetic reasons so I assume you should be able to buy imperial and metric versions.
  3. BarnsleyRob
    The alternative solution is this:
  4. Vin Petrol
    I'd guess it was coding, now whether you can reprogram that via the ODB2 with a dealership level tool I'm not sure. Maybe someone who's imported a Copen and had it done the other way around might know how it was done, or you could try asking for a quote from somewhere that imports?
    Odometer Rob not the speedometer, the mileage readout.
  5. Number6
    Yeah, Odo not Speedo.
    The DS-2 doesn't allow for changing from miles to km, so I'm assuming that I'd have to remove the unit and alter the chips
  6. BarnsleyRob
    Ah, okay. It will probably require a new unit and then find some way to adjust the odo to the true mileage (km) which would normally be done at the dealer but we’re a bit screwed on that front.
    I’m pretty sure it’ll be the same chip but just factory configured differently.
