The first problem is the interior light is not working when the switch is on the "door" it never turns off it stay on all the time, the second problem is when I use the fob to close the doors it gives three clicks and the light comes on and off three times too, I know it suppose to do it twice. How can I fix these two annoying pain in the you know what? Sorry just getting frustrated. Please can anyone help? Thank you in advance! Cheers!
Check the switches at the bottom of the door openings. They are covered by a little rubber grommet. My guess is one of them isn't detecting that the door is closed. Thus the light stays on.
It depends what/if anything has happened to the switch. It could be that the switch has been knocked & is not touching the door when closed. So either fixing the switch or adding something to the door so it touches the switch. This might not be the cause of the problem though, it is only a possible problem.
You were right, the switch was not touching the doors when they were closed. So I put like a piece of rubber on the doors and both are working perfect! Even the lock is working. Thank you so much, you made my day!
