MOT failure
Discussion in 'Problems, Fixes, Tips...' started by Kev pye, Jan 20, 2017.
  1. Kev pye
    Kev pye Copenworld Newbie
    Leamington spa
    Only owned my 06 since December 16 new it needed a engine which I have replaced with a donor and now is running lovely now she's failed MOT on corroded rear sills does anyone know how much this is likely to cost but I'm still pleased with my purchase
  2. welz
    please take some pictures from the sills, so we can look of them.bad:(
  3. Kev pye
    Leamington spa
    Thanks for responding it's two holes both size of Apple sorry I'm not very good at taking photos the mechanic said a weilder can put some plates in rather than new sills would that seem a good idea and then paint them in later
  4. Salieri
    I don't know how much its going to cost, not too much probably.
    I would go for welding in new metal and sealing the whole car with rust inhibitor/wax/oil
    But apart from that, take good care of your car. Take care of maintenance religiously otherwise you'll need another engine soon :D
  5. Vin Petrol
    Apple is a pretty big company, if the holes are that size is there any car left? :p
    Not even got my Copen yet, picking it up Tuesday, but I'm planning to get it up on a ramp or stands and give the bottom a proper inspection, I've read they do have rust problems since they weren't designed for salted roads.
    Advice here says to give it a good clean (wire brushes, don't use a jet wash, high pressure water getting into little crevices is exactly what you don't want) then seal it with something to prevent rust, still looking through various reviews on which exactly to use, but most say the black WaxOyl is awful and the worst choice, clear version might be ok.
  6. Kev pye
    Leamington spa
    On the engine maintenance I'm checking my oil frequently and Will filter and oil change every 3000 miles and when the weilding done I intend too intensive rust proofing my car came with only 1 key and fob would like to get another set again haven't got a clue how easy it is to get another set
  7. Chrismadeley
    Canterbury, Kent, UK
    Copen Vivid Special Edition
    I had holes in both sills at the front of the rear wheel arches where the water trap is patched with welded-in plates and some damage repaired behind one of the front wheel arches for £400 plus VAT by a local firm. That price also included a touch-up to a corroded corner on the front of the bonnet!
  8. Kev pye
    Leamington spa
  9. Kev pye
    Leamington spa
    Finally have a MOT weilding cost 150 for patches on sills been quoted 280 for tarting up rear arches didn't think that's to bad looking forward to getting to drive her such a fun car I think it's going be well worth it
    Your Majesty and Vin Petrol like this.
