Lift Qtr Windows(with roof down)
Discussion in 'General Chat' started by funsiz, Sep 25, 2009.
  1. funsiz
    funsiz Copenworld Newbie
    Sydney, Australia
    Copied from http://www.copenownersclub.org.uk
    After opening the roof you can press and hold a little button where usually the roof-catch grabs in (see red arrow in pic)
    If you then operate the windows up while holding the button, the 3/4 windows will go up first, then the normal windows.
    The 3/4 windows will remain up until you start closing the roof again.
  2. machinehead
    Thanks for the tip - very useful and I'm going out to try it now!!
    M.
  3. Rex
    Maybe I’m being over cautious, but don’t you think there is a reason the little windows won’t go up with the roof down?? Anybody found any problems?
  4. Coxsie
    Coxsie Copenworld Member
    Watford Herts
    Copen + Signum
    No reason to be cautious, as the Qtr windows are checked by the roof control logic. They are lowered automatcally when the roof closing sequence starts.
    I've not had a problem, as I always have them in the up position with the roof down, I think it helps keep the air disturbance to a miminum inside.
    Also in the cooler weather they help to keep the heat from the blowers where you need it. :)
    YAK likes this.
  5. Rex
    Okay,
    Thanks for the reassurance Coxsie, I give it a go.
  6. Brad
    Brad Copenworld Newbie
    Zama, Japan
    2002 Copen, 1999 Dodge 3/4 Ton Ram, 2002 Gino, 1999 Harley Davidson Sportster
    I'm super late to this posting but it's a sunny spring day here in Zama, Japan and I'm going to try this on my way home!
