My Copen has been letting water into its boot. I have tracked the leak down to a plastic cable clip behind the rear bumper. Has anyone removed the rear bumper on their Copen? If so please will you advise on fixings and procedure. Thanks Ivor
I removed the rear bumper of mine. When the boot lid is up you will see three bolts on the top of the bumper. One is behind the number plate. Two behind each arch going up into the wing. Are you sure the water isn't getting in through the centre brake light? It's a very common problem. https://www.copenworld.com/vb3/showthread.php?t=1361 https://www.copenworld.com/vb3/showthread.php?t=1389
Thanks Adam Thanks Adam - this is really helpful and I will give it a go. I did suspect both brake light and spoiler initially but they proved OK. I moved on to seals and eventually found water entering through the cable fixing clip and emerging along a seam. Several hours with a watering can - my life is so sad!!! I'll post to update. Ivor
