Having had continuing bad reception from the little windscreen stick-on DAB aerial outside of towns or cities I was contemplating a DAB/FM splitter so I could use the existing Copen FM aerial. Trouble is there are two versions of splitter: Powered (a wire connects into the loom to power the splitter box) Unpowered (no additional power connections required as the aerial is already connected to power which the splitter unit uses) So……. Does anyone know if our little Copens have a powered or non powered aerial? Anyone else fitted one of these aerial splitter units?
I had a new double din screen fitted professionally and they tried to use the existing aerial for both FM and DAb but we’re not successful so have a screen DAb aerial which seems to work fine, better in fact than DAb in my Jag
