I bought a Copen! But with a problem
Discussion in 'Introductions' started by SemJohnson, Jun 12, 2024.
  1. SemJohnson
    SemJohnson Copenworld Newbie
    The Netherlands
    I bought a 2006 Silver 1.3 Copen. Only thing is that the left part of the boot stays a bit up when it closes. It attracts it electronically good when it closes, but at the last second the left top part goes up. Does anyone know if it is a sensor or alignment issue?
  2. Tieak
    Tieak Copenworld Member
    Stirlingshire
    Copen 1.3 2007
    Fiat 500
    Seat Leon
    Greetings,
    I had a similar sounding problem - mine was because one of the two blue tabs in the boot used for manually opening the roof was not seated properly. Once I moved it back to its correct position (comparing with the other side may help) the boot closed fully.
