Handbrake Gaiter
Discussion in 'Modifications' started by Number6, Jan 3, 2014.
  1. Number6
  2. alz2605
    alz2605 Copenworld Regular
    Ceredigion
    VW Golf TDi
  3. Number6
    Yeah, I was thinking that. Remove the rubber one? I'd say I'll have to, as there's not enough room either side.
  4. alz2605
    Ceredigion
    VW Golf TDi
    I didn't have to remove anything. It's just a cover & sits over the original part.
  5. Your Majesty
    West Midlands
    Copen, no other car.
    Top Tip for the Handbrake handle cover
    If you're putting on a leather cover around the top of the handbrake it might not stay in place on it's own, so if you've put one on and are finding that it slips about too easily try this:
    Firstly wrap around some double-sided tape onto the the handbrake handle. Then fold back about a third of the cover onto itself as if you were turning it inside out but don't turn it completely inside out, just some of it. This makes it a bit easier to slide all the way on.
    Then (and this is the top tip) get your hand wet and slop water all around the tape. You can then slide on the cover without it sticking straight away and get it nicely into position. The water will dry away after a while and the cover will be stuck down with the tape. :cool:
  6. dunf
    dunf Copenworld Regular
    Fife, Scotland
    You can use hairspray instead of water. Lubes when wet then dries tacky.
  7. Your Majesty
    West Midlands
    "Hairspray"? - that's a bit too close to "Hairdressers", a word that is strictly forbidden on this site! :)
  8. Number6
    Ok, it's really simple - it slips over. Use a long spoon, wrapped in tape, if you don't have a trim tool, to stuff it down.
    I'll do up a video at the weekend, if I have time.
  9. Number6
