Gearbox oil
Discussion in 'Problems, Fixes, Tips...' started by AFR0N1, Nov 14, 2019.
  1. AFR0N1
    Owners manual says either GL3 or GL4 oil can be used and it should be 75w90 and 2.1-2.25L is required.
    Question is what is the best gearbox oil to use for the 659cc Copen?
    And
    Can GL4+ be used? (reason for asking is Castrol Syntrans Transaxle 75W-90 was recommended but it is GL4+ rated and the description says it is compatible with GL4 but I want to know for sure)
    You have already answered your own question. Use Castrol Syntrans Transaxle 75W-90.
    It is specified as GL4, the + is a marketing term used to indicate a higher amout of extreme pressure and anti wear additives.
    AFR0N1 likes this.
  3. AFR0N1
    I was wondering what that + was about
  4. welz
    AFR0N1 likes this.
  5. AFR0N1
    I changed the fluid and it went well. Gearbox feels a bit smoother then it did before (might just be in my head)
    I didn't have a long extension bar to be able to reach the fill plug through the wheel well, but I did have a pretty long spanner and I could just reach the fill plug from the engine bay and I could remove the drain plug if I crawled under the car with it raised up.
    Here is the part number of the gasket for the drain and fill plug incase anyone needs it:
    90044-30178-
    Salieri likes this.
