Does anyone know what this part is called?
Discussion in 'General Chat' started by DanHargrove, Aug 23, 2024.
  1. DanHargrove
    DanHargrove Copenworld Newbie
    Worksop
    2005 Daihatsu Copen
    Good morning.
    Does anyone know what this hollow bolt in the front wheel arch is called and if there is a way to find a replacement and both mine are almost rusted through. Picture attached. Many thanks, Dan
  2. Shahram Azimi Nobar
    Egham
    2007 Daihatsu Copen 1.3L
    Hi Dan,
    I believe the part number you’re looking for is 90041-20174 – Bolt 6 × 12 mm (with washer). You can order it from Japan through sites like Impex, which is where I usually get most of my Copen parts. However, if this is the only part you need, it might not be worth the cost unless you’re planning a bigger order. You could also try checking with your local Toyota dealer or even shops like Homebase or B&Q.
