After 6 months of hard work and dedication, I finally managed to finish my engineering project ranging from software development to electronics engineering, and I'm ready to finally show some pictures off! *No modifications or alterations of the original parts of the car are needed, everything is plug and play!* The project consists of: - some PCBs developed by myself for original attachments with signal conversion boards for every dash light and signal e.g. speed, rpm, fuel level etc. - a Raspberry Pi 5 with a 4-LiPo battery pack from Geekworm - a display with 2400x900 resolution from Aliexpress - a high speed OBD2 link for realtime diagnostics - 9 Axis sensor with altitude, G-force and more! - 3D printed mounts for every board, PCBs, sensor and display here - a custom hand-crafted software from the ground up with everything needed The digital dashboard has everything the classic physical dashboard has (nothing left behind!), with the following additions: - A newly made Fuel Low signal (wow!) - The RPM and Speed are inverted, to give it a more sporty look - Realtime telemetry data of all the things happening inside the vehicle for future analysis - 5G networking for remote telemetry data (CopenCluster Portal) so you can see all your data in there! - Automatic Trip data in kilometers - Cloud Cover, Rain/Snow probability, Outside temperature from open API over internet via coordinates usage - Realtime coordinates data for trip tracking for making 3D maps of your sporty weekends - Realtime statistics like Engine Load, Intake Temp, Intake pressure and Battery Voltage - Instantaneous and Average fuel consumption in km/L and L/km - Fuel short and long term trims for seeing if your engine is fine in realtime - Engine fault codes in realtime without going to a mechanic, with proper messages show in the display itself! - ...and so much more with the analysis of the telemetry data in the cloud portal! All of this is already functioning in my car, I'm still doing the finishing touches in the web portal so we can save, for example, mechanics jobs, tires usage in kilometers left or time, inspection dates, car services triggers after kilometers or time and so on! Stay tuned for more info about this, in the meantime have a great day!
Thanks for the feedback! Yes probably, I'll finish the project first and then try to think of a solution regarding building more for others, I'll make sure to let you all know if that's feasible!
I would certainly be interested in one of these as well. Would it work with the 659 engine as well? I have one brought over from Japan.
