Copen 1.3 First Stage..
Discussion in 'Modifications' started by marinos_84, Dec 21, 2016.
  1. marinos_84
    marinos_84 Copenworld Member
    GREECE
    Daihatsu Copen 1.3L (2008)
    Hello Copeners!!!
    This is my little monster..
    Power:86Hp (at the wheel)
  2. BUZZBOX
    BUZZBOX Copenworld Newbie
    Perth Australia
    2013 WRX RS 40
    2004 Copen K3-VE2 conversion
    A few bikes
    Nice What have u done to it so far?
  3. marinos_84
    GREECE
    first stage my friend..
    1.handmade manifold,
    2.I have removed the catalyst,
    3.racing exhaust cauldron,
    4.racing air filter,
    5.parallel ecu program
    and.. in the future wild camshafts...and flow field development.. (this is the end)!!!
    Khalid likes this.
  4. bobbyboy
    bobbyboy Copenworld Newbie
    Gold Coast Qld Australia
    Daihatsu Sirion GTVi
    Hey marinos, I have a Daihatsu Sirion with the same 1.3 k3ve engine and am looking at performance modifications. Can you explain the parallel ecu program? Is it an ECU that runs parallel with the stock ECU or is it a way to flash tune the read only ecu on the k3s?
    Also, so you know for future reference, I think you can only change the exhaust camshaft while keeping the vvti in the stock ECU, otherwise you have to have an aftermarket ECU to run the vvti set up or skip the vvti altogether. Or so I've heard.
  5. marinos_84
    GREECE
    Yes, it is ECU that runs parallel with the stock ECU..
  6. gotboost?
    gotboost? Copenworld Regular
    Brisbane, Australia
    I believe Marinos means a piggyback ECU.
  7. jcuyckens
    jcuyckens Copenworld Member
    Belgium
    Volvo XC60 2015
    Toyota Corolla 2004
    Rover 45 V6 2005
    Daihatso Copen 2006
    BMW R850RT & R850R
    Yamaha GTS1000 1993
    Hello, i am looking for installing a piggyback ECU, could you tell us what make and type you have. Do you have schematics for electrical connection and possibly some advise about settings, troubles that you faced in the adjustment of this ECU?
  8. marinos_84
    GREECE
    Nothing problem my friend..
    My ECU is Greddy e-manage blue (parallel).
    The link was made by a developer.
