C1251 error code
Discussion in 'Problems, Fixes, Tips...' started by Shiftyseamus, Mar 1, 2025.
  1. Shiftyseamus
    Shiftyseamus Copenworld Newbie
    Shropshire
    Hi, all new owner and just trying to get my Copen through an MOT.
    One of the faults noted was brake fluctuations. I've scanned it and it comes up with C1251 code(pump motor resovoir system).
    Google hasn't really helped much, anyone had any experience with this?
    Sean
  2. GuzziMan
    GuzziMan Copenworld Member
    Densole Kent
    Hi Sean
    As far as I can make out on page E3 – 19 it states replace the ABS actuator. The sensor may simply need cleaning, hope this helps.
    Shiftyseamus likes this.
  3. Shiftyseamus
    Shropshire
    Cheers, I've bought a replacement pump and will chuck that on.
  4. GuzziMan
    Densole Kent
    Hi Shiftyseamus
    Revision on information. It states in the manual: - Making sure that the all the ABS wheel sensors on all four wheels are clean and do not file clean. Clean gently with non-metallic tools and then double check wire connection for each one, to ensure electrical continuity. Do not disturb the distance between the sensor and the disc. In the manual it’s a very finite measurement parameter. These are essentially passive control. (The manuals are accessible on this web site)
  5. Shiftyseamus
    Shropshire
    Hi, I've fitted a new pump and the errors have cleared.
