Braking when reversing
Discussion in 'Problems, Fixes, Tips...' started by Will, Jul 11, 2016.
Tags:
  1. Will
    Will Copenworld Newbie
    Bristol
    Hi guy ive just been wondering what the problem with my 1.3 copen could be, when I reverse and break it makes a horrible noise, sorta like a screech or a grind. Either way if you have any mechanical sympathy you will cringe, all help is most appreciated
  2. Almichie
    Almichie Copenworld Newbie
    Wiltshire
    Either poorly adjust drums or worn front pads
  3. Will
    Bristol
    When I bought the car only a few months ago, everything was fine, its only recently. Plus when going forwards and breaking there is no noise at all.
  4. Salieri
    Just check your brakes, how hard can it be? It is pretty much the only component that might pose a problem :D
  5. Number6
    Sounds like the drum brakes in the rear - my money is one the shoes having worn
  6. Bemused
    Bemused Copenworld Regular
    Stoke-on-Trentishoe
    I would guess at rear shoes also. Particularly as the shoes will tend to pick up in one direction and not the other when worn.
