Brake Fluid
Discussion in 'Problems, Fixes, Tips...' started by opboy, Oct 2, 2012.
  1. opboy
    opboy Copenworld Newbie
    Hi all,
    wanna check usally we only top up brake fluid if it fall below the min level or every 2 years got to top up according to the manual? A bit confuse.
    Btw can use Dot 4 for 660 copen?
    You need to replace all the brake fluid every two years.
    Section E1 of the service manual mentions Dot 3 brake fluid.
    If you need to top up the fluid above the minimum level you probably have a leak somewhere. If you have a leak air could also get into the system. Air is compressible so your braking could be effected. Check for leaks & repair.
  3. opboy
    Thanks Adam, was reading the manual and need some clarification. Will take a look of the brake fuid level tomorrow when have time..
