Hi, changed the abs pump on my Copen and I'm struggling to bleed the brakes. I've used a pressure bleeder and it looks like all of the air is out. However the pedal is still no good. Is there a procedure for doing this? Thanks Sean
Hi Sean, yes there is a procedure in the Service Manuals - 1298cc model v2, in the resources section of this sight. For the 659cc it’s under section E1-1 through to E1-4 regarding airtight performance check. Hope this helps.
