Boot not working
Discussion in 'Problems, Fixes, Tips...' started by Yellow fellow, Jul 15, 2019.
  1. Yellow fellow
    Yellow fellow Copenworld Newbie
    Hull
    Good afternoon, my wifes pride and joy has decided to play up during the few weeks that a convertible makes sense in our sceptered isle.
    When I closed the boot (after making sure it was safe to open the roof) it did not make the noise and pull the front down. To open it I have to pull the cable and the blue tabs. I have disconnected the battery for a reset and it worked once. Now we are back to square one.
    Could someone post a close up picture of the latch mechanism on the hinge with the boot open please as I am not sure if the white plastic slider should be at the front or the rear of its channel when the boot has opened normally.
    Thanks in advance .
  2. AFR0N1
    I hope this helps.
    If you need a different angle, just say the word and I'll make it happen.
  3. Yellow fellow
    Hull
    Thanks for the speedy response.
    If you can see the white plastic slider and the latch I need more of a close up of that particular area. Thank you.
  4. AFR0N1
    I hope these help :)
  5. Yellow fellow
    Hull
    The pictures are great thanks.
    I will get down to the workshop tomorrow, I believe that it has lost its position and these are the key.
  6. Yellow fellow
    Hull
    Well I have reached the point of don't break it further. The most local ex Daihatsu dealer will be having a look on Thursday.
    I did the bridge it out and the blink code was showing 24 which is boot switch. I could not clear the code though .
  7. BarnsleyRob
    Smart move - quit while you’re ahead.
  8. Yellow fellow
    Hull
    The diagnosis is the lower, latch motor has been damaged by water and now the boot doesnt know its position so will not operate.
    The parts come to £300 odd and have to come from Japan.
    Watch this space .
  9. BarnsleyRob
    I’d be tempted to look for a replacement on eBay. There haven’t been too many, if any, mentions of failed motors on the forum before so you should find a cheaper alternative.
