Axle Stands - where?
Discussion in 'Problems, Fixes, Tips...' started by LauraF, Jan 1, 2019.
  1. LauraF
    LauraF Copenworld Newbie
    Derby
    Daihatsu Copen, Seat Leon, Fiat Cinquecento
    Hello,
    I need to get my Copen up on axle stands for a few weeks whilst I rust proof the underside etc. I have found some forum threads and the Daihatsu manual with the official jacking/axle stand points labelled, and although I have easily found the initial jacking points for my trolley jack, I am not confident that I can spot the correct place for the axle stands by the sills.
    Has anyone actually done this before who could point me in the right direction? A picture of the correct front and rear points for the axle stands would be amazing.
    They are basically where the notches in the sills are (on the very front and the very back)
  3. AFR0N1
    Like Salieri said, on the notches on the sills.
    There are also front and rear jacking points.
  4. LauraF
    Derby
    _20190103_195549.JPG Thanks both, that's a great help.
    I have found the notches I believe (see pic) and I have made some wooden blocks to fit over the sill lip at these points to help spread the load over the axle stand a little. It'll be up on stands for at least a month so hope it is OK.
  5. BarnsleyRob
    It’s called a pinch weld. If you look on the famous auction site, you can get rubber pucks fairly cheaply that will offer better protection especially if it’s going to be there a while.
    You could have had mine but I junked them last month !
