Active top Alarm buzzer - won’t lock properly
Discussion in 'Problems, Fixes, Tips...' started by Okibearded1, Apr 12, 2021.
  1. Okibearded1
    Okibearded1 Copenworld Newbie
    Okinawa, Japan
    2005 Copen
    Hey professionals, I searched the forum and couldn’t find the answer to what I perceive as a common problem....
    The active top buzzer in my 2005 Copen won’t stop. The top goes up and down without issue but even after I latch the roof closed the red light does not go off. I played with the adjustments of the left and right latches as it was pretty loose. Could it be too tight? (It’s really not). Can I disable the buzzer? Is there something else I’m missing besides there is an obvious disconnect with the switches to deactivate the light. Any idea/fixes?
    There are two microswitches that are being pushed in by the roof latches, you could try to move them by hand just to see if it has any effect. Maybe one of the switches is broken
  3. Rex
    With the roof down, does the warning light go out / buzzer stop?
